  #1
Old 03-15-2009, 08:40 AM
bucks77ford's Avatar
bucks77ford bucks77ford is offline
We will Rise Again
bucks77ford has a reputation beyond reputebucks77ford has a reputation beyond reputebucks77ford has a reputation beyond reputebucks77ford has a reputation beyond reputebucks77ford has a reputation beyond reputebucks77ford has a reputation beyond reputebucks77ford has a reputation beyond reputebucks77ford has a reputation beyond reputebucks77ford has a reputation beyond reputebucks77ford has a reputation beyond reputebucks77ford has a reputation beyond repute
Neutral Safety Switch
OK, so I went to install my neutral safety switch and I am a bit confused. The shaft that the NSS is supposed to slide on doesn't have any grooves and also there is no spot for a mounting/retaining bolt. Here is a pic of my transmission. Can I even mount a NSS switch on there?
1977 F250 4x4 Highboy
521 Stroker D44/60 C6
  #2
Old 03-15-2009, 11:11 AM
Ranger429's Avatar
Ranger429 Ranger429 is offline
Ranger429 has much to be proud ofRanger429 has much to be proud ofRanger429 has much to be proud ofRanger429 has much to be proud ofRanger429 has much to be proud ofRanger429 has much to be proud ofRanger429 has much to be proud ofRanger429 has much to be proud of
What year is the trans case from? It doesn't look like it is threaded for the NSS to mount to. Here's a pic of mine.
_____79 F-250 429 36" Cepeks__________________79 Bronco 400 35" Cepeks_____
  #3
Old 03-15-2009, 11:19 AM
We will Rise Again
Ranger, not even sure what year. I told the company who I bought the tranny from what I had and went from there. Not until now did I notice this. It sure is very different from yours. But, yeah, it doesn't look like it was made to have a NSS mounted there. It must be an older tranny. They never asked me though if the NSS was mounted on the column and I never told them. Never gave it a thought. I guess I just thought a NSS could be mounted on a C6 without any troubles.
  #4
Old 03-15-2009, 11:22 AM
Ranger429's Avatar
It looks like your only option is to figure out what year the case is from and use an NSS from that wired to your truck or don't use one. Not having an NSS is a pretty big gamble though. That sure does suck.
  #5
Old 03-15-2009, 11:35 AM
We will Rise Again
Quote:
I'm betting the tranny wasn't made for one and I am supposed to use one mounted on the column. Problem is, I have a 79 column so I can't do that, or can I.
And yes, it is a gamble not having one and I won't have reverse lights either. This sucks.
  #6
Old 03-15-2009, 12:49 PM
Mil1ion's Avatar
Mil1ion Mil1ion is offline
Mil1ion has a reputation beyond reputeMil1ion has a reputation beyond reputeMil1ion has a reputation beyond reputeMil1ion has a reputation beyond reputeMil1ion has a reputation beyond reputeMil1ion has a reputation beyond reputeMil1ion has a reputation beyond reputeMil1ion has a reputation beyond reputeMil1ion has a reputation beyond reputeMil1ion has a reputation beyond reputeMil1ion has a reputation beyond repute
The 77 trans does not have a transmission mounted NSS
on the 77 it is on the column
1978/79 is transmission mounted like his pic above.
A LEO born in the year of the TIGER,so don't mess with ME
I speak in "Straight Talk" Deal with it.
Click for Red Deer, Alberta Forecast
  #7
Old 03-15-2009, 03:00 PM
We will Rise Again
D, is it possible to mount a NSS on a 79 tilt column? I'm not worried about the wiring since I have to run new anyway. Otherwise, I may end up switching out that shifter in the tranny and taping out that stub for a bolt and see if I can mount that switch there. One bolt should work to hold the switch.
The other idea my brother and I had was to use a relay and figure out how to use the brake light switch as a NSS. I won't have reverse lights, but at least something. I figured I would have to apply the brake to open the switch in order to start the truck. Just kicking around Ideas. If anyone has anything they'd like to share let me know.
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
