1990 ford E350 460 motorhome
Hello ,
I have a motorhome that fuel issues ,so had into shop .
They changed intank sending unit and pump
Changed high pressure pump , new filter , new pressure regulator.
And still will not start . Will fire on starting fluid but dies.
Fuel gauge on rail read less than10 psi .
Jumped pin to continue running pump and pressure will not go above 30 psi .
Turn key off and pressure drops to 0
Have checked computer and all looks good no leaking capacitors.
Am going to try another regulator today, as will not hold pressure.
If not I think maybe the injectors . As the tank was pretty rust when issues started before all this started.
Everything in fuel system is new except the injectors.
Thing is driving me crazy now!
Makes sense if leaking pressure but not actuating. Might pull spark plugs to see if they are wet.
Changing the regular did not make a difference.
Have ordered be injectors , as this is the only thing in fuel line that has not been changed. I can get it to idle but bit rough , and cannot rev it up at all .
