I recently discovered that both tone rings on each of the front shafts were cracked. In order to keep teh ABS from coming on I had to disable the sensors. I thought the rings could be replaced but everyone says it's better to just replace the half shaft that includes the tone ring since you pretty much would have to take the whole thing out anyways. Plus I checked with the dealer and they won't sell you just a tone ring either.
After getting a price from a dealer I started checking online for aftermarket parts. I recently replaced the lower control arms with some aftermarket oen and saved about $100 per side. What I need to find out is how many teeth are on the tone ring and the spline tooth count and the overall length of each shaft because there are a significant number of aftermarket manufacturers out there and even looking for the specific year, make and model there are some variations.
