With aftermarket speedometer gauge do you still use speedometer cable from transmission IE 1972 c6
Apr 10, 2020 #1 Ltteg70 With aftermarket speedometer gauge do you still use speedometer cable from transmission IE 1972 c6
Apr 10, 2020 #2 dustybumpersdon't play well w others3,291188 In my own world Most are electronic. You use a halls effect sender. There should be a description of what you need as far as an adapter, and sender with the gauge Sent from my SM-N960U using Tapatalk
May 12, 2020 #4 Blue-Truck-Nut97crank polisher55118 Just to add to the above response, there is also a GPS unit available to run aftermarket speedometers now. I got mine at Speedway, it has worked well for 248k miles now, though it does loose signal anywhere a normal GPS does. Just a thought. Sent from my E6810 using Tapatalk
