7.3 powerstroke failure
have a 99 7.3 that loses high pressure oil after warming up replace high pressure pump and ipr and known good icp any help would be thankful
How many miles on it? If the base engine oil pump is worn out, or bearings prevent it from supplying oil to the reservoir in sufficient quantity, you'll have that problem.
bowtiehatr
Certified Ford Tech
probably injector orings. if you dont have block off tools, you can remove the valve covers and watch for oil coming back up from around the injector.
d-kuzmen
Master Ford Tech
2,109
79
Connecticut
Check the injector Orings, being a 99, they have revised orings out for the 7.3's, I change them all the time.
