My 97 F150 threw a P0302 and P0401 the other day, I traced the miss fire to a loose injector plug. I reset the codes last weekend, I got in the truck and went to the Dump and to town to pick some stuff up. It threw the EGR code again, so this morning I did a little checking on the EGR I cranked the truck and disconnected the FPR vacuum line and hooked it to the EGR valve and the truck died down but didn't completely die. Now the green line that went to the EGR valve felt like it had a slight bit of pressure coming from it. Is this normal? I did pull the white feed line from the sensor and it had good vacuum. That sensor also makes a humming sound when you cut the truck off.
Thanks for any help or suggestions.
