Connections, cables, solenoid or starter.
Checked connections and cables. I'm going to brush them off now, but they look clean. Any test to perform on the starter?
Austin....do what I said a few posts back...turn the headlights on and take a battery reading...or take the battery out and get it load tested.
Check your ground cable. If it still has the oe cable on it, check where it bolts to the frame. I`ve seen where it`s just a strap wrapped around with the insulation off and they corrode. Pull it off the bolck and wire brush everything. Bend the cable at the lug end and see if you can get a peak at the wire to see if theres any green visible.
atleast when my Red Flareside was done for a while it was cause it needed head gaskets.. yours is just a battery probably... or even worse.. a connection....
so sad...........................
Good looking bronco.
Thanks Cliff!
Got Blue running today - turns out the cable going from the battery to the starter solenoid was bad (I noticed it sparking when I tried to jump the solenoid). Hook up a jumper from the batt to the solenoid and test, test confirmed. Of course I had to let her run, and drive around the neighborhood, and make some excited phone calls.
Then I realized how much of a PITA this cable has been to me. Completely overlooked it.
Fluids need replenishing; power steering especially.
