bucks77ford
We will Rise Again
I finally took on the task of replacing my blower motor on my 75. The original one worked but squealed so bad at times it hurt the ears. I never replaced one before with factory A/C while the evaporator box was still in the truck. What a PITA. It only took me all day and of course it was 95 degrees out. I also replaced the heater core while I was in there so hopefully it will be good for a long time. I did add a bit of extra wire to the blower motor and made it so I can at least access the blower motor from under the hood. I ground off the rivets holding the plate on the black box under the hood and turned the clips around so the motor can mount right. The motor shaft comes very close to the plate, but does clear barely. Than I just used some small bolts to mount the plate back on. Seams to work just fine. The blower should last a long time but figured if I ever need to replace it, it will be a much easier task.
