Lost
PA Chapter leader
Well allot here will know MY 94 F150 Which had a new Ford trans (not re man) with 9100 miles started to push fluid .
Fluid is coming from bell housing aka the pump . Luckily it happen in my driveway
And I parked truck as soon as saw fluid trail in snow . Check fluid and not frothed up . So overheating should not be issue .
So here's the question??
Once I get trans out and I remove pump should I use another pump or just seal? I do know outer seal is usually the problem .
What do you think.
What do you think.
