Is this a rear mounted tank in-between the frame rails? If so yes, it will be tight and you will need new or fab some mounting brackets and make a deeper fuel pick up tube
Bronco tanc works, but the frames are different. You have to make your own lower straps, and use the hanging unit for inside the bronco tank.
The fuel sender is wired different, and requires the bronco end to the tank. Junk yard can provide that.
