Talk to me about the early 6.0
lil_dq
Let 'er eat boys!
6,933
265
Union, MO
I am calling on a 03 6.0 in the AM and before I make the trip to OK for the trade (if they still have the truck) I want to know if there is any tell tale signs of the issues on these trucks.
Here is the truck. Something about it just keeps bringing me back to it. I know it needs some interior work, but I am trying to get it on a title for title trade on the F150...
http://www.autotrader.com/fyc/vdp.j...s=25&seller_type=d&cardist=281&standard=false
Here is the little that I know. Our Subcontractor bought a 2003 6.0 new and has it as of now.
Unit has (I think) 200k miles. It gets him around 17 mpg (imp).
The first couple of years were plagued with ongoing update flashes.
Last year EGR went..$3k fix.
He loves the truck, runs a sled deck.
I'm thinking if it is a stock truck (no piggyback) and the Oasis is good then it should be a sound truck.
lil_dq
Let 'er eat boys!
6,933
265
Union, MO
I am going to call them in the AM. If they still have it, then I will have an oasis run. Neighbor down the hill just had his excursion done, and it cost him about $2500, but got new head studs, EGR delete kit, and a few other mods. This truck looks stock from what I can tell.
Key Time In Service Labor Hours Dealership DIST (Miles) Repair Date Prefix Base Suffix Doc
Details 3334494 5 .4 SMITHVILLE FORD, INC. 11707 04-NOV-03 * 1K105 * 012940A
Customer Comments CHECK HUBS WONT UNLOCK
Tech Comments REPLACE SANP RING SET
Details 7467433 14 .6 COLLIER FORD 29989 09-JUL-04 * 18806 * 014607A
Customer Comments CHECK RADIO INOP
Tech Comments REMOVED RADIO
Details 7902779 14 0 VISTEON AFTERMARKET - U.S. 29986 09-JUL-04 * 18C815 * 97565109
Customer Comments
Tech Comments REQUESTING DEALER'S P/A CODE 08604
Details 11594355 26 5.7 JOE COOPER FORD OF TULSA 52996 28-JUL-05 3C3Z 9E527 AE 02728801
Customer Comments VEHICLE HAS A RUNNING CONCERN WILL ONLY IDLE
Tech Comments BAD INJECTORS. CC 42 CP 9E527 F350 6.0L AUTO TRANS 4X4 MIL OFF, KOEO P1111. VERIFY 6.0. 6.0L PERFORMANCE DIAGNOSIS. KOEO SELF TEST. KOEO INJECTOR ELECTRICAL SELF TEST. KOER SELF TEST. BOOST PRESSURE TEST 11 PSI. FUEL CONTAMINATION CHECK. INJECTOR INTERRUPT FOR ENHANCED DIAGNOSIS. FOUND CYLINDERS 4 AND 7 MISFIRE. R AND I VALVE COVERS ON BOTH SIDES, REPLACE INJECTORS FOR CYLINDER 7 AND 4. CLEARED CO
Details 11594354 26 3.2 JOE COOPER FORD OF TULSA 52996 28-JUL-05 3C3Z 6K854 DA 02728802
Customer Comments CHECK FOR EXHAUST LEAK
Tech Comments CC D8 CP 6K854 6.0L F350 4X4 AUTO TRANS CHECKED EXHAUST LEAK. FOUND Y PIPE FOR TURBO WAS LEAKING. R AND I TURBO FOR ACCESS. REPLACED Y PIPE ASSM. ROAD TESTED AND VERIFY REPAIRS.
Details 12871570 31 9.1 JOE COOPER FORD, INC. 53671 21-DEC-05 3C3Z 9E527 AE 016569E
Customer Comments VEHICLE RUNS ROUGH COLD
Tech Comments 53671 DID PERFORMANCE STEPS1 15. ALL WITHIN SPEC BUT RAN ROUGH. REPROGRAMMED WTIH LATEST CALIBRTION AND RETESTED,STILL RAN ROUGH. DID POWER BALANCE TEST AND FOUND CYLINDERS 2 AND 3 WEAK. CHECKED COMRPESSION ALL WITHIN SPEC. REMOVED BOTH VALVE COVERS AND REPLACED FAILED INJECTORS 2 AND 3. REASSEMBLED AND TEST DROVE NOW OK.
Details 12871571 31 2.9 JOE COOPER FORD, INC. 53671 21-DEC-05 3C3Z 6700 BA 016569G
Customer Comments C S OIL LEAK FROM ENGINE AREA
Tech Comments 53671 REPALCED FRONT CRANK SEAL COVER 6007D 0.5 6700A 1.9 VERIFIED OIL LEAK,ADDED OIL DYE TO OIL,TEST DRO VE, USED UV LIGHT TO SEE OIL COMING FROM BEHIND CRANKSHAFT DAMPNER,DRAINED COOLANT,REMOVED AIR ASY,REMOVED BELT,WATER PUMP ,PULLEY CRANK SHAFT DAMPNER INORDER TO RUN VEHICLE TO BLACKLIGHT CRANKSHAFT AREA,FOUND THAT OIL WAS COMING FROM FRONT CRANKSHAFT SEAL,AND LIGHT UV
Details 14622935 42 .7 JOE COOPER FORD OF TULSA 86094 06-NOV-06 * * * 516852H
Customer Comments PERFORM RECALL 06E17 RECALIBRATION
Tech Comments 86094 06E17B 0.7 REFLASH CONTROL MODULES TO LATEST CAL.
Details 14622936 42 11 JOE COOPER FORD OF TULSA 86094 06-NOV-06 3C3Z 9F838 EA 516852A
Customer Comments CUST. STATES OIL LEAK IN ENGINE AREA.....
Tech Comments 86165 VERIFY 60, ENGINE OIL LEAK DIAG. INSTALL OIL DYE AND ROAD TEST. USED BLACK LIGHT FOUND OIL LEAKING FROM ICP SENSOR. REPLACE ICP SENSOR AND CLEAN ENGINE. ROAD TEST AND RECHECK. OIL LEAKING FROM OIL PUMP COVER AND REAR ENGINE COVER. RR INTAKE ASSY, RR TURBO, RR HIGH PSI OIL INJECTION PUMP COVER. RR 2 PIECE DRIVE SHAFT, RR AUTO TRANS, 4X4. RR REAR ENGINE COVER AND CLEAN.
Details 14622934 42 .3 JOE COOPER FORD OF TULSA 86094 06-NOV-06 * * * 516852G
Customer Comments PERFORM RECALL 59B01 ROAD TEST
Tech Comments 86094 59B01A 0.3 TEST DRIVE
Claim DetailsclosePrint
Close
lil_dq
Let 'er eat boys!
6,933
265
Union, MO
Sounds like half the injectors have already been replaced. I may only need to do the EGR delete and Head studs.
lil_dq
Let 'er eat boys!
6,933
265
Union, MO
Thanks Vince!
The price sounds too good to be true lol. Around here gas trucks with almost that mileage are going for around that price.
lil_dq
Let 'er eat boys!
6,933
265
Union, MO
I have been finding them, but the truck gets gobbled up to quick.
lil_dq
Let 'er eat boys!
6,933
265
Union, MO
No trade on that one. They wouldn't pony up.
mrxlh
Oilfield Trash
5,904
430
Stigler, OK
Take it for what its worth, 03 MY was the best 6.0 built. Many never were touched. I had a company truck that had over 200k on it without a single injector replaced.
384
i will say this...
the only reason you hear so many bad things about the 6.0's, is they at the time were the MOST produced diesel engine in almost any class..
the percentage of issues compared to actual engines out there, is pretty comparable to any other engine..
