what viscosity do you use? NEW POLL.
what viscosity?
  • 0w20
    Votes: 0 0.0%
  • 0w30
    Votes: 2 6.5%
  • 0w40
    Votes: 1 3.2%
  • 5w20
    Votes: 10 32.3%
  • 5w30
    Votes: 5 16.1%
  • 5w40
    Votes: 2 6.5%
  • 10w30
    Votes: 9 29.0%
  • 10w40
    Votes: 1 3.2%
  • 15w40
    Votes: 8 25.8%
  • Total voters
    31
Ken, I am curious to see how the 0W-30 does in the '77 and '79.
Same here. I would have never thought to run that.
I could have picked up about 6 cases of that at $5 a case.
I haven't had the chance to put many miles on the 79, so I'll know more this upcoming summer.
But on the 77, when I first got it home in 2010 (? I forget), the newly, highly, rebuilt 400 initially had regular petroleum 10w40 to break in the motor.....after a few talks with the original engine builder in Seattle and with Amsoil techies, once I got it home and the ODO rolled over 10k miles, they gave the ok to flush the engine with detergent (from Amsoil) and put in 0w30 because of where I lived.......
Almost no hard starts in the winter as I still start the truck every couple of weeks during its winter storage.
During the hottest days of the month, the average temp dropped 20 degrees, but I think some of this was due to the radiator solution Amsoil sells (Chris?)......I put this in there, cause if you fellas remember back then, I was running the roads pretty good that first summer going to car shows with it. Changed the oil in it for the first time since then (only 3k on it since 2010 and I know it sat in there for a few years, but even when I drained it, it still looked almost new, replaced the filters (dual filtration system on it, added on by the PO) and even the filters (from Amsoil also) looked great with hardly any noticeable dirt in them....really blew me away.
^^^wanted to stay with 0w30 for the new f150 and expi, but after talking with Chris and the Amsoil techies, their signature series 100% synthetic 5w20 is best....so that's what I'm going with this spring.
384
The coolant boost is an awesome product. Your temp drop was a combo of the coolant boost and the all synthetic oil. Less friction less heat, then add in the coolant boost which helps absorb then disperse heat... Hard to beat..
The only other oil I would suggest to ya Ken would be the Zrod.. It's SUPER high in zinc and is specific for older flat tappet modified engines. But only comes in 10w30 and 20w50.
But with the amount of time the truck sits id stay with the signature series for the TBN retention.
384
Yeah on a completed stock modular 5w20 is the ticket. I only suggest 0w30(North) or 10w30 (south) for modified modulars.
384
I guess I should post up what I'm running lol..
Running obviously Amsoil 0w30 signature series in the Flareside, and Amsoil OE 5w30 in the taurus. Running 5w30 in the taurus cause the original design was for 5w30 and then they back spec'd it. 3k miles later on the OE and it hasn't burn a drop. Still really clean. BUT that is NOT how you determine OCI's!!! Can't stress it enough. Visual inspection of oil does no good
What ever it had before, wen I changed it, it was 2 qts low. Only had 3k miles on that OCI. Gonna move it up to signature series next time.
You don't list the oil I use smilietease
They don't make it yet...5W-50
384
Didn't think of it, don't hardly ever see it cause very few use it.
That's cause 5w50, especially the motorcraft shears BADLY down to a heavy 30.
So me and a few other dealers suggest to guys running gt500's etc, run a 10w30 if down south, or a 0w30 up north if year round driven. Otherwise if stores during winter a 10w30 is the money. This is plenty unless a pure track car. Then we suggest the Dominator line 15w50 for only track driven cars.
The big reason why the 5w50 shears is it's got to large of a gap, so they use heavy Viscosity improvers, and those lose potency really quick.
5-20 Valvoline synthetic in Her Gran Cherokee....per specs..
5-30 Valvoline High Mileage..in the Wrangler....per Higher mileage
10-40 Castrol GTX..in the Ford......Period correct viscosity
10w40 in the trucks. 10w30 in the edge. 5w-20 in the Lincoln.
mrxlh
Oilfield Trash
5,904
430
Stigler, OK
15W40 in the SD, RV genset, Lawn Mower, Welder, and the quads, 10W30 in the power washer, 20W40 in the boat, 20W50 in the Harley.
Chris im Kind of a skeptic on running 0w30 in an old school engine...would you share some light on the subject..Thanks
20w-50 havoline in the '78 F250 with 400. 15w40 Delo in the Cutlass with '69 350. 10w30 Havoline in '00 Grand Prix. Older engines have larger clearances, so I prefer a 15w40 or 10w40 in an older engine that's freshly built or a 20w50 with an older engine with more miles or with a small leak or if they smoke some.
