351W High Output!
Got a whole donor truck so I can do a EFI 302-Carbed 351 swap finally!!
Now that I got the engine out, I have some major degreasing to do! Then replace some gaskets, water pump..etc, painting it, then dropping it in my truck! Cant wait!
What all will I need to do this swap? Will I need the harness off of the donor truck? I'm planning on putting a MSD ignition in too...
And intakes..should I keep it stock, or get aftermarket?
384
what size holley is that?
about all i would do is put a better cam in it, roller rockers, GT40 heads. the D8 or E5's that are on there, are terrible! E7's are even a step up. but if you go up to E7 you might as well go GT40's.
i'd go aftermarket only if you feel like you'll go wild later down the road.
complete engine regasket. but don't pull the bottom end apart.
make sure you do timing chain, oil pump, head gaskets.
but thats just me..
but thats just me..
It's a 600cfm Edelbrock.
I might just leave it stock..for now. Maybe GT40 heads and a intake. Thats all I'd do at this point.
Engine re-gasket is already planned. Leaving the bottom end together.
Adding performance heads & cam without doing the bottom end is a recipe for disaster.but that is me as well! especially on a high mileage engine,be warned!
primetime
sawmill slave
smilieIagree smiliewhathesaid I`ll also never put another used engine in without pulling rod and main caps for a look see.
While its out, I would at least do an overhaul on it. I am really kicking myself for not checking mine out.
