E4od but what signal is it looking I've got the engine in and running but had gotten rid of some the modules under dash like the waring buzzers and abs module being the 79 doesn't need any of it
E4od won't work. Needs signal to pcm from several different things on the engine.
You can get a stand alone controller, but would still need input from the sensors. Tps, vss,, and
Bauhman makes a good controller. I can post the info later when I get home.. i know several of the diesel guys went that way,, worked well for themsome others
I think this is what Dustybumpers is referring to, seems like he sent it to me once. Turns out I didn't need it on that project so can't say I've used it. https://www.becontrols.com/e4od.shtml
I've did a bunch of googling and you tubing but it took me almost a day to come across that controller need to climb under my truck and see what pig tails I have exactly them boxs rsng from 600-1000 $ and I'm going to have to swap the rear end out now to being my sendor from the old truck is there and not at the trans
