A/C compressor Seals
Guys,
I have a 1997 F-150 XLT w/4.6l and my A/C blow a leak, all of the freon leaked out over night. I recharged the system and added die, but I can't tell where the like is, I did see small amount of die around the compressor clutch. But the clutch appears to still be working. I can hear a leak coming from around the compressor area. Can you get new seals for the compressor? or should I just get a new compressor kit (w/ Drier and orifice tube), Where do I find the Orifice Tube? Also, It has an inline A/C filter, Should I replace it as well or can I just leave it?
Thanks,
George
Most often its the o-rings where the lines bolt to the compressor.
A/C compressor lines
Blacksnapon,
The manual (Haynes and Chiltons, both) say remove the hoses from the compressor before removing it. The compressor is underneath and I can't see how to get to the bolts on the lines with out dropping the compressor down. Is there a better way?
Thanks,
George
