Better Throttle Response
radialarm
Clown of Death!
It's 4" for our single dwelling.....I was just trying to stir it up while you plumbers were talking shop...
2 bath- 2 1/2 baths use 3", 3 and above use 4"!!!
That will be $65.00 Sir!!!
So, I need to make my intake tube smaller and get that velocity back?
Try a piece of 2.5" pipe.. hopefully you'll leave it black this time.smilieloser
You may have an issue with your TPS as well, did you transfer the one from the stock TB? If so did you test the voltage at the closed position? It should be about 0.9v.
flareside_thunder
7,812
246
MMMk thanks Paul... I'll probly make 2 different intakes...one or 2 inch and one for 2 1/2 with adapters. I was told .98v is optimal by the Gen 1 Lightning guys...
Watchdog7
Guarding the Gates
276
7
What size is your straight pipes? 302's aren't known for low end grunt and you might be robbing it by "exhaust over kill".
flareside_thunder
7,812
246
Nice flareside man, welcome to the site. I've got 2 1/4 pipe running into a Thrush welded muffler then runnin straight out the back in 2 1/4.
Yea i bet you do. There not adjustable on these trucks like my stang. Unless your aftermarket TB lets you adjust it.
