racsan
4xford
well today i was changing my front shocks & on the passenger side i twisted off the nut/threads for the lower mount (on the radius arm) still had the stub for the shock to go on. i drilled into the mounting point, tapped & threaded it for a 8mm bolt. put the new shock on then used a 8mm bolt, nut & a fender washer to retain the shock to the stud. i put the nut all the way onto the bolt, slid the washer on, tightend the bolt until it stopped, then tightend down the nut. i then cutt off the excess bolt sticking out past the nut. (didnt know if the tire would get into it in a turn, thought id better to be safe) any reason this "repair" wouldnt work long term? not sure if id need a whole new radius arm to do it right, didnt look at the backside of the arm to see if the shock mount stud was easily removeable. drivers side came off with no problem. truck had the origninal front shocks on it, i did the rears about 4 years ago & never got around to the fronts until now.
