egr
str8racing
half fast mechanic
Have egr code, cleaned per manual tried to clean intake, still get code. valve works ok with vacuum test. Any ideas? How to clean manifold opening better?
kevin9
New Jersey Chapter member
38
2
what kind of truck and engine do you have?there is a part called the dpfe sensor that has a high fail rate
Showing EGR flow? I take it you mean..
332 - Insufficient EGR flow detected
That was not the code that I was getting when my DPFE was malfunctioning. The valve is vac operated-- you sure you dont have a vac leak?
kevin9
38
2
you could have excessive egr flow also which would point to the dpfe,put a vacuum pump on the egr valve fitting and with the engine running pull a vacuum on the valve,the engine should stumble possibly stall.if it does your passages are clear.it is possible for the egr vacuum solenoid to be bad carefully check your vacuum lines for proper mounting and locations.if you need more help let me know i have access to pictures and test procedures,good luck
