well i want to go ahead and do the upgrade so i can stop the bronk a little better only problem is i have a brand new booster and master cylinder on and i dont want to just waste money. anybody want it
well you learn something new everyday ill have to be getting a proportioning valve
That says just doing the MC/booster has a good probability of making your brakes worse due to volume and whatnot of brake fluid.
The thing is you have to install the F350 PPV as well.
Scott...were these going from old MC's and boosters to a new 350 setup?
What 1968/79 F350 has a specific disc brake proportioning valve? None.The thing is you have to install the F350 PPV as well. The F350 PPV has a slightly different design.
IF the booster is from a 1979 F350 with 4WD, the prop valve is exactly the same as one in the OP's Bronco.
