Factory Tire size
Could have been anywhere between a 7.50 x 16 to a 9.50 x 16.5, depending on wheelbase and GVW. Sorry, Matt, I just repeated what you said. I'm just trying to get to 30,000 posts. :wasntme:
Either 7.5x16 or 9.5x16.5...what aguy has to reach 50k some how.
That conversion on a stock tire is roughly 31" tony.
SuperCab
547
Montana
Which is a 235/85/16 (skinny) or a 265/75/16 (wide). Both of these are roughly 31 inches... Both of these sizes are very common and should be easy to find used ones if you want...
I have 4 of the 9.5 x 16.5 brand new tire mounted and balanced if you drive to Alberta lololol
Really happy with the 265/75R16 that I bought to replace the skinny 235/85R16 that it had. Feels better on the road with more contact, JMO
Looks like the speedo readings are exactly the same, also.
SuperCab
547
Montana
In 16" tires, there are 3 common sizes: 29", 31", and 33"
Both have a narrow and wide variant.
29" = 215/85/16 narrow and 245/75/16 wide
31" = 235/85/16 narrow and 265/75/16 wide
33" = 255/85/16 narrow and 285/75/16 wide
This is all going off memory but I think it's accurate.
And just for the record, the half ton would take a 225/75/15 for the factory equivalent size IIRC
Actually the F-150's took an L78x 15 which is a 235x78x15
Tire sizes:
The first 3 digits is the tread width in mm's
The second set of numbers is the %age of the tread width
THe third set is the rim diameter
