- 48
- 1
Hi all. When changing intake manifolds on an FE engine, can you simply un-bolt the rocker arm shaft and bolt it back on after swapping intake manifolds WITHOUT having to readjust the rockers ? I'm assuming on a stock 360 they're NON-adjustable rocker arms to begin with. I would ensure the push-rods go back into the exact same lifters, but I know I have to remove the push-rods to remove the intake manifold. Any help from those who have done this is appreciated. Thank you.
