fly wheel problem
geojet
geojet wants to
my torque conveter bolt moved 1/2 inch from mounting to my fly. i dont want to pull the engine just to correct the problem. is there any way i could get enough clearance to adjust the flywheel to the torque conveter or vise versa.
im asuming you just installed the engine,you may need to access the tourqe converter by removing the starter & take a long prybar & try to bring the converter forward to its mounting holes.do not force it or bind it up.the converter should slide easily foward if it is free & the studs are not bound to the flywheel.
