HazzardMadWolf
Go Fast Turn Left
He's got an 04 F150 got the 4.6. Replaced the fuel pressure sensor. Truck was spitting and sputtering, then finally died. He replaced the sensor like I said, and it started right up sounded good, he put in reverse made about three feet and it died. Wouldn't even crank after that. He's trying to get a code reader to see what codes it might be throwing. It probably will be tomorrow before he can get that done though. I told him to reset the computer by disconnecting the battery for awhile. I told him after he reconnects the battery to turn the key to the on position and make sure the fuel pump is cycling. I couldn't think of anything else, how bout you guys? By the way thanks for the help in advance.
