hey guys little update and a question. i got the f150 on the street, it rough but it now safe to drive. i finished rebuilding the front axle end to end with a posi unit. replaced all the brake lines, hard and soft as well as calipers rotors and pads. the hard lines are the stainless set from Jeff's bronco grave yard. worth the money. i did the wheel clinders and master/booster when i got the truck.
just been using her on the week ends now i know a ball joint wont brake off, the drive lines wont pogo stick, and i can stop hard with out maybe blowing a line.
anyways the next item is to redue the full system up to the engine. this truck came with a 20 gallon fuel tank. can i just buy a a 40 gallon tank with 40 gallons straps and bolt everything up. or do i need to change somethings?
