Gas Tanks
Not quite enough to get you past that next gas station. I have a 20 gal front tank and an 18gal rear tank.
Typically the 19 up front and 18 in the back... Going to try a Bronco tank on the 92 F350, it is off a bit dimension wise, but it has the straps in the same place, so we'll see how it goes... Not going to happen for at least another month, after classes. 33 gallon rear, much better than 18...
