1973 F-100 4x4
'77 F-250 Custom 4x4
I finally got around to fixing the fuel gauge not working issue on my current DD.
It is a '74 F-250 Custom 2wd, 360ci engine with NP435 4spd.
I spent a few hours on wednesday dropping the fuel tank to change the sending unit.
Mind you, the tank was 3/4 full still, and I did not have a jack tall enough to help lower or raise the tank. Just the help of a friend.
Man was that thing heavy!!
After all that, found out that the sending unit was good, and the fuel gauge itself was bad!
(Lesson learned: check the gauge first!)
So I swapped the gauge cluster with the one out of my '73 F-100 Custom 4x4. Which is exactly the same, but is in a lot better shape.
Now, my temp. gauge isn't working.
How hard would it be to swap out the temp. gauge from the old gauge cluster?
Both are still solid, not brittle as they tend to get after awhile.
Any advice would be helpful, as I have to drive 22 miles out of town this sunday.
(18 miles of it is all dirt back roads, and where I have to go is literally 20 miles away from any city, town, or civilization in general. This is to go to my landlords ranch.)
Thanks in advance.
Thanks in advance.
