master cyl, ps lines
Mar 10, 2011 Moderator #21 blacksnaponModeratorStaff member9,461301 waynesville,mo. master cyl, ps lines
Mar 10, 2011 Moderator #22 blacksnaponModeratorStaff member9,461301 waynesville,mo. pcm connectors, connectors under ps reservoir
Mar 10, 2011 Moderator #25 blacksnaponModeratorStaff member9,461301 waynesville,mo. connector under driver battery for fog lights
Mar 10, 2011 Moderator #26 blacksnaponModeratorStaff member9,461301 waynesville,mo. remove nut and route wires to pass side
Mar 10, 2011 Moderator #28 blacksnaponModeratorStaff member9,461301 waynesville,mo. ground strap pass side under windshield
Mar 10, 2011 Moderator #30 blacksnaponModeratorStaff member9,461301 waynesville,mo. Whats not shown, a/c lines on the dryer, and in front of the radiator (pass side. Theres an electrical connector, and ground on the pass fender. Set the rack, lift the cab.
Mar 10, 2011 Moderator #31 blacksnaponModeratorStaff member9,461301 waynesville,mo. remove the fan and shroud.
Mar 10, 2011 Moderator #33 blacksnaponModeratorStaff member9,461301 waynesville,mo. alt and glow plug controller
Mar 10, 2011 Moderator #35 blacksnaponModeratorStaff member9,461301 waynesville,mo. turbo pedestal, engine wiring.
Mar 10, 2011 Moderator #36 blacksnaponModeratorStaff member9,461301 waynesville,mo. fuel lines, fuel and oil filter housing REMOVE INTAKE MANIFOLD
Mar 10, 2011 Moderator #38 blacksnaponModeratorStaff member9,461301 waynesville,mo. remove ficm and brackets
Mar 10, 2011 Moderator #39 blacksnaponModeratorStaff member9,461301 waynesville,mo. pass exhaust manifold and trans dipstick
Mar 10, 2011 Moderator #40 blacksnaponModeratorStaff member9,461301 waynesville,mo. remove valve covers
