New to the forum - looking for advice/guidance on my 76 F-250.
It's a 390 with a 4 barrel carb - 11 year old crate motor with ~30,000 miles on it.
I recently replaced the head gaskets, and while I had the heads off I had them machined and rebuilt, and the intake manifold hot dipped
The carb was rebuilt less than 500 miles ago
I replaced the head gaskets, exhaust manifold gaskets, and intake manifold gasket (I used fel-pro gaskets and the cork "front & back" gaskets on the intake)
Changed the oil and coolant, then once I got the motor back together, I fired it up. It ran really rough for about 20 seconds, and I cut it off. When I attempted to start it again, the starter quit on me. It was late, and I had to head out of town the next day, so I left it for a week. When I came back, I replaced the starter, and now it cranks but won't start. I am getting backfires through the carb ("spitting".) I am also seeing the distributor loose its timing. I will set the motor to TDC, pull the distributor and set it to #1, crank the motor, and after it cranks for a bit (without starting) I will advance to TDC and the distributor will be 180 degrees off. I have replaced the distributor - but the new distributor exhibits the same behavior. Spark is good on on all cylinders, the carb is getting fuel, and I checked compression on #1 and #5 - and it was 92 PSI - which was the same compression I had before I pulled the heads. I have checked the valve train and the valves seem to be functioning fine. I'd appreciate any help or advice to get it running. Thanks much -
