My eddie bauer has been spot on for 10 years after I did all the suspension work. Sealed the oil leaks, some other things.
For the 10 years, only minor things. oil changes, etc.
I did tune it up last month, plugs looked good, needed a cap and rotor. used a better set this time with brass posts.
This truck is a 4.9 5 speed.
I imagine an automatic would do well.
My 94 was abused and totaled when I got it, so putting it together was the same
I did have to put a transmission in it.
10 years, on a motor with over 200,000 on it last year it started missing, and I could have kept running like that, but chose to freshen it up. That is a 5.0ho with a 4r70w 4x4 automatic transfer case.
I imagine whatever you get will hold up well, and serve you for whatever you need.
I assume the 2 week wait you refer to is the covid. I wish you well, several of my friends have run right on through with no issues. some not so lucky.
Be well my friend
Be well my friend
