So I was getting the truck ready to do some work today, and then it just died while it was running. I was 1/2 way from my back barn to my front garage. So I noticed the Edge Juice Turned off. Hummm I then checked to see if there was a fuse or power wire some where. Nope just wires in between all the sensors. I then unplugged all of them and plugged all the factory ones in. No go, I then checked all the truck fuses. Fuse 30 blew, it had a 10A and called for a 30A, got a new fluse, pop as soon as the key is turned on. Fuse is for Diesel fuel heater, Injector Drive Module, and PCM Relay. Ok so I did a quick Google and they say to unplug the heater and try again. Hell Yes, fired right up. Need a diesel fuel heater in the fuel filter housing now!!!
