low pressure oil pump
Its labor intensive depending on what you do. The shroud and stator must come out. Harmonic balancer, pump cover. Now, Depending on the reason why you're replacing the pump, the front cover may be scarred and grooved, thus, it will need replaced. Updated front covers also change the size of the water pump, so the pump would need replaced as well.
i sure thank you for the info . truck just wouldnt start a repair shop tested it said its the LOP so if i can find what parts i need im going to try and tackle it my self
