Bought truck 145. 500 miles on it
Told had CEL but would run Idled fine would make a 50 mile trip home but it came home on a tow truck I originally posted :
Here's the symptoms it starts and idles but you have a strong smell of gas it will not move more than 35 or so and it takes forever to get it going. It also feels like a misfire. the CEL is on and it spit out five codes the first two came up twice.. they are
P0174 system too lean Bank 2
P2197 O2 sensor stuck lean Bank 2 Sensor 1
P0430 Catalyst efficiency below threshold Bank 2
We checked for a vacuum leak and found none A shop mechanic told me that the left side catalytic converters were probably jammed causing the computer to make truck go nuts Replaced the left side cats with a Walker direct fit replacement,& both 02 sensors truck still ran shitty and I was advised to check PCV valve which I also replaced Also when they pulled out the left side cats it was determined that the muffler was jammed with pieces of the old cats so i replaced the muffler and they made sure that the pipes were clear. CEL has remained off since this repair It still runs like crap and had a miss. Did another scan and was told the spark coils were bad replaced all 8 spark plugs and coils 4 OEM 4 NAPA still ran rough
Guy at the shop told me that it was a trans issue so i took it to a trans shop who said it was NOT a trans issue He stated that we should prolly change right side cats which we did . no change in the conditions of the truck
Did two trips to Staten Island and we heard a noise from the fuel pump that it was whining erratically , replaced fuel pump and screen ( screen was dirty) no change
Truck still runs like shit
I cannot continue to throw money at it as its not working any other suggestions. As of now still no CEL
