bucks77ford
We will Rise Again
If I had a garage, my truck wouldn't be Orange.....
I agree, nice garage to work in
It does beat trying to work outside and it is heated
You are making good progress!
Thanks Duncan. I was trying to get to a point of primer before it gets too cold so I wouldn't have to run the heat much, but I think I will miss that window.
Buck..Just tell the wife "priorities take presidence over the van...and yes dear ill clean the snow off your windows"....hehe
Ya, that's a must. Keep the van clean of snow.
A little more progress. I got the drivers corner cut out and replacement fitted. It took some hammering on the door jam side and I'll have to tack weld starting with the front and working my way toward the rear to get the rear to fit where it should be. Not too bad though. It's amazing on how much crap came out after cutting the corners. Alot of dirt, rust and even a couple of petrified baby mice. The metal on the passenger side looks pretty good. There is quite a bit of surface rust on the inside and on the very bottom on the outside. Seems solid, but I think I'm going to cut a section out below the body line and just replace it with new. I have to imagine that it won't be long before it rusts out, especially on the very bottom where crap sits. So for a piece of mind, I'll replace the small section. No need to cut more original metal than needed.
