No Compression #2 cylinder
Has anyone else seen this. New to Forum. Did compression check after truck smoked and stalled. Had injectors check and were okay. Is there instructions to remove cab?
Thanks
384
Ok well I still wouldn't be yanking te cab off yet.. I'm not any good with diesels, but we have a few who are especially BlackSnapon.. He's a ford senior master tech. Just be patient and when he gets on next, he should point you in the right direction...
But he may need more info
If its had issues before (egr cooler, injectors, etc.) the place it usually shows up is #2 and/or #8. Look in my post 6.4 headgaskets and high pressure fuel pump how to. I've got step by step pictures.
