Oasis request
Status
Not open for further replies.
2 recalls too
Standard Claims List For Model Year 2008
Detailed Vehicle Specification
VIN VEH LINE MKT DERIV BODY CAB VER SERIES DRIVE TYPE PLT CD TRS CD ENG CD PROD DATE WARR DATE SELLING DEALER SELL CNT TIS WCC CPSC_6 PREF BASE SUFF CCC CD DIST(Miles)
1FTWW31R88EC64623 T/F7 F T/BC T/CD T/E A1 T/BE T/QL 05-OCT-2007 19-OCT-2007 152001 USA 1 2G01 031401 * 12A650 * D50 42 533
AWS Claim Key: 225124 Trx Code: S07 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 02478 - * Name: MIDDLEKAUFF FORD Ph: 972-9853600 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:01-NOV-2007 Doc #:681246A
Cust Comments: D50 WHEN ACCEL FROM A STOP W TRAILER THERE WAS A SHUDDER AND A LOSS OF POWER BOOST WULD COME ON BUT DIDNT MAKE ANY DIFFERENCE
Tech Comments: 536 COULD NOT DUPLICATE PROBLEM 6005F,F1,F2,F6,F13,F19,12650D45 1.5 PULLED TRUCK IN AND FOUND TRUCK IN GOOD RUNNING CONRITION. PULLED TRUCK IN AND CHECKED CODES AN D FOUND NONE. RAN PINPOINT TEST AND FOUND EVERY THING IN GOOD RUNNING ORDER. RAN FUEL PUMP PRES SURE TEST AND GOOD AT 9 PSI. INJECTOR SELF TEST PASSED. FUEL CONTAMINATION TEST PASSED. TRUCK I N GOOD RUNNING CONDITION AT
1FTWW31R88EC64623 T/F7 F T/BC T/CD T/E A1 T/BE T/QL 05-OCT-2007 19-OCT-2007 152001 USA 7 2G01 031401 8C3Z 12A650 DKD P51 28 6441
AWS Claim Key: 741308 Trx Code: S07 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 04948 - * Name: GARY SMITH FORD INC Ph: 850-2444111 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:16-APR-2008 Doc #:09586151
Cust Comments: TRANSMISSION IS SLIPPING AND SHUDDERING WHEN SHIFTING AT LOWER SPEEDS ESPECIALLY WHEN TOWING
Tech Comments: VERIFIED PCM AND TCM SHORTED MIL BODY CHASSIS ELECTRICAL (BCE) TEST
1FTWW31R88EC64623 T/F7 F T/BC T/CD T/E A1 T/BE T/QL 05-OCT-2007 19-OCT-2007 152001 USA 8 5C02 050101 EOTZ 4A209 A P51 42 8238
AWS Claim Key: 1307388 Trx Code: 2 Labor Hrs: 0
Dlr Cd-Sub Cd: 09713 - * Name: RODEO FORD Ph: 972-9853600 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:28-MAY-2008 Doc #:691346A
Cust Comments: VEH BUCKS & SHUUDERS WHEN PULLING SWAY FROM STOP
Tech Comments: REPROGRAM PCM RD TEST VERIFY CONCERN INSTALL ONE SHIM ROAD TEST STILL EXISTS INSTALL 2ND SHIM ROAD TEST STILL EXISTS INSTALL 3RD SHIM MADE WORSE
1FTWW31R88EC64623 T/F7 F T/BC T/CD T/E A1 T/BE T/QL 05-OCT-2007 19-OCT-2007 152001 USA 9 2G04 000615 * DIAG * D42 82 9683
AWS Claim Key: 1090333 Trx Code: 2 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 09713 - * Name: RODEO FORD Ph: 972-9853600 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:24-JUN-2008 Doc #:692673A
Cust Comments: D42 LACKS POWER, HAVE TO DRIVE VERY HARD WITH LOAD, LAST TRIP GETTING 5 MPG
Tech Comments: 9683 WARR EEC TEST PASS . PID MONITOR PASS. ROAD TEST PAS S. ALL SYSTEMS PASS.
1FTWW31R88EC64623 T/F7 F T/BC T/CD T/E A1 T/BE T/QL 05-OCT-2007 19-OCT-2007 152001 USA 9 5C02 050104 7C3Z 4831 A S25 42 9683
AWS Claim Key: 1090334 Trx Code: 2 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 09713 - * Name: RODEO FORD Ph: 972-9853600 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:24-JUN-2008 Doc #:692673B
Cust Comments: S25 SHUDDER VIBRATION PULLING AWAY FROM STOPS
Tech Comments: 9683 CC 42 ROAD TEST CK RIDE HEIGHT CK PINION ANGLE CONTACT FORD HOTLINE ADVISED TO CK PAY LOAD WEIGHT AND TO CK DRIVEANGLES R R DRIVE SHAFT REPLACE CENTER SUPORT BRACKET ON FRAM RAIL RAISED CENTER SUPORT UP POST ROAD TEST
Status
