Rebuilding steering column?
Is there bearings and such available to rebuild a steering column? Mine is shot. Also anybody know where I could get a new ps pump pulley?
Plans for the truck in the next couple months consist of all new vacuum lines and get rid of the inverted y so I can run a pitman arm for the lift that's on it. Then redo the steering column because it's junk
Jasperrc
Texas Chapter member
CGFordParts should have everything you need to rebuild the column although I haven't looked at a parts diagram to confirm.
The PS pump pulley part number I found for your 76 F150 with a 360 is C7AZ 3A733-E. Might not be a bad idea to confirm the part number with what you already have on the truck. The pulley might be harder to find but it looks like they pop up on eBay occasionally. Maybe get a pump off a newer truck in a salvage yard?
BKW
Ford Parts Guru
The PS pump pulley part number I found for your 76 F150 with a 360 is C7AZ 3A733-E. [confused]
No part numbers marked on parts since 1956.
C7AZ-3A733-A (replaced C5AZ-3A733-F - Marked AF) .. P/S Pump Pulley / Marked: 7AA / Obsolete
1968/72 F100/350 360/390 with A/C / 1973/76 F100/350 360/390 with/without A/C
