- 9
- 0
I'll try to keep this short, I took my 2003 SD in for fluid changes. Front/rear diff, tranny, transfer, brake, power steering and coolant. Got my truck back and the rear diff cover had been R/R as it had sealant oozing out. The front diff had not been touched, the brake calipers have not been touched $nor was the transfer case. Now from the little research I have done it looks pretty much impossible to flush the brakes without leaving some kind of mark on the calipers. Same goes for the transfer case, it looks the same as when I dropped it off. Unless they can drain the fluid without spilling a drop anywhere? I can't tell if the steering fluid has been changed, I plan on sticking my finger in there today to have a look at he color. Is it possible to flush out theses item without leaving a teach of it anywhere? And yes this was a large Ford dealership.
