wizzard351
ride'n on 35's
anyone know of a way or some kinda kit that'll let ya run an old trans like a C-6 with a cable speedo on a 92 that has an elecric speedo?
You can get a speedo sending unit out of an early 90's crown vic. They go into the tranny in the same spot as a cable would and have the gear on them. Just stick it in your tranny and run your vss wires to it. It's a pulse generator, the same signal as what you have. You may have to change the nylon gear on it to correct your speedo, if you can't by reprogramming it.
Anybody happen to have a conversion chart?
I think you have to go trial and error. When I was looking for a chart, I was told none existed. The factory only had info for what combos came stock. Later on, I ended up ditching the stock gauges and went digital. That set up is self calibrating.
