jebadiah04
Rooster Snorkler
- 849
- 27
Hey guys,
I am going to swap out my speed density for a MAF system. Mostly for the sole reason of swapping out heads and cams, I want to make this baby run a lot stronger than she does now.
I have a couple questions that I'm trying to pin down, and I'm hoping you all will look over my e-build and see what you think about my plans.
EEC-IV computer out of a 94-95 mustang. I think this should be Code T4M0 (i need confirmation on that)
73MM MAF Housing (its only 1 butterfly instead of 2, how the hell do you hook that up?)
OEM MAF sensor from 94-95 stang (self explanatory i guess)
i found this harness...not sure if it will work, i am wondering should i swap to a bronco/f series harness or use the one i found or just add the wires i need to mine. I need some input here. heres the harness (http://www.latemodelrestoration.com...v2&year=1986&gclid=CImLvbWtgb4CFU4R7AodRn4A-w)
Am I on the right track here? Yes i know there are tons of threads and eerrrrbody has done this, but i like contributing to the forum
