- 1
- 0
Has anyone done a a timing chain on a 2000 Ford Explorer 4.0 overhead cam engine? I need a diagram to line the teeth up correctly. Thank you in advance for any help!
You need the tools to do it correctly. You start at the rear of the passenger side head.Has anyone done a a timing chain on a 2000 Ford Explorer 4.0 overhead cam engine? I need a diagram to line the teeth up correctly. Thank you in advance for any help!
