tranny question
anyone have any info/opinions on borg warner t-10 4 speeds. theres a local add for one for sale for 150 it needs to be rebuilt though. it would go behind my 390 (396 as we astablished in my previous thread) i want to know if this is a good deal or should i pass or should i not even think about using that kind of a tranny
thanks guys
T-10??? Not a tranny expert...but I thought it was a t18. I'd say it's fine tranny. Unless of course you have a 4wd truck...then you'll be limited to tcases that are single speed...which brings the suck.
im no tranny expert either hahah its goin in my 55 f100 def not a 4x4 here is the add
FORD/MERCURY HEAVY DUTY 4 SPEED TRANSMISSION,COMPLETE.
DON'T BE A CHICKEN ****,TAKE IT APART AND REBUILD IT! SAVE MONEY $$$$$!
Rebuid KIT ONLY COSTS ABOUT $100. ON E-BAY.
ITS BETTER TO PUT A NEW REBUILT 4 SPEED IN YOUR HOT ROD.
THAT WILL SHIFT GREAT,AND LAST A LONG TIME!
GOOD FORD 4 SPEED TRANSMISSIONS ARE DIFFICULT TO FIND!!!
1961-1965 FULL SIZE,FORD OR MERCURY.(WILL FIT OTHER YEARS)
MAINCASE CASTING #T-10-H-1, DATE CODE IS 72.CAST IRON CASE,VERY STRONG!
T-10'S USE DIFFERENT TAILHOUSINGS FOR DIFFERENT SHIFTER LOCATIONS.
(WILL ALSO FIT 1966-UP,IF YOU CHANGE TAILHOUSING)MUSTANG/COUGAR,ECT
THIS IS A VERY RARE 4 SPEED TRANSMISSION.FITS SMALL BLOCK OR BIG BLOCK
10 SPLINE INPUT,27 SPLINE ON OUTPUT, 26" LONG FROM MOUNTING EARS TO TAILHOUSING
TRANSMISSION MAINCASE DATE STAMPED 72,
***HAS DUAL BOLT PATTERN FOR 6 CYLINDER,OR 8 CYLINDER BELLHOUSINGS***!
I ONLY WANT $350.FOR TRANSMISSION,BECAUSE YOU NEED TO TAKE APART TO REBUILD.
EVERYTHING LOOKS GOOD,EXCEPT BRASS SYNCRO'S ARE WORN.
SO IT SHOULD BE BEST TO REBUILD.(REBUILD KIT ABOUT $100.)
ALL GEARS ARE IN GOOD CONDITION.A GREAT TRANSMISSION TO REBUILD!
CASES ARE CAST IRON,SO MOUNTING EARS ARE STRONG,(ALUMINUM BREAK/CRACK OFF)
*GREAT FOR RANCHERO,FAIRLANE,GALAXY,THUNDERBIRD,CUSTOM F-100 TRUCK,OR HOTROD.
JUST TAKE OUT 3 SPEED,POP IN 4 SPEED,
FRONT SPLINE,CLUTCH,BOLT PATTERNS,ARE THE SAME.
(YOU MIGHT HAVE TO SHORTEN DRIVESHAFT A FEW INCHES,OR GET ANOTHER DRIVESHAFT)
CUT HOLE IN FLOOR,INSTALL BLACK HURST BOOT,
YOUR TRUCK OR HOT ROD WILL BE WORTH ALOT MORE MONEY $$$ ,
WITH A 4-SPEED TRANSMISSION,CHROME HURST SHIFTER,AND HURST BOOTY!
Oh...ok well I'll defer this to someone else...I was thinking this came out of a bump/dentside.
