Transmission Dip Stick Leaking
Transmission fluid is leaking from the dip stick at the transmission. Not sure if there is supposed to be an "O" ring or anything. The dip stick is loose. How can I stop the leak?
If no one knows, I can check mine tomorrow as it's out...pm me to remind me.
It's recommended to also put a small coating of RTV around the O-Ring before you install the tube into the tranny. Did this on my C-6 3 years ago haven't had a leak yet.
BKW
Ford Parts Guru
Do you know the size, and it's 1 ring.
1) 87034-S94 .. O-Ring-Transmission Dipstick Tube - 9/16" I.D. / Available from Ford
O-ring used for decades on all FoMoCo vehicles with Ford-O-Matic ~ FX/FMX/MX Cruise-O-Matic ~ C4 ~ C6 ~ AOD and etc etc etc!
DNFXDLI = If you have the 1973/79 Ford Light Truck Parts Catalog, you can look this puppy up in Text - Section A70.4 - Page 14 .. it's listed below the 7A228 dipstick tubes.
Catalog available on a CD from hipoparts.com
