trck flow heads and Intake
Ok so I have a 460 that was rebuilt 1 year ago and has stock 22cc pistons and I am rebuilding the top end for street and strip application and I was wondering how well the trickflow heads and intake would work with my stock 22cc pistons and a qft carb 850 cfm and what cam would you recommend with this application if I am trying to reach 550 to 575 horsepaower...
Thanks
Matt
1970Custom
They call me Spuds
14,107
447
Middleton, ID
You're going to be a long way off with stock internals. 600hp is stroker territory...
Trick Flow top end is a good start though.
You will need to do some research on what camshaft will work well with those heads, because the stock camshaft is very conservative and made for engine longevity and reliability. It has a lot of room to grow, though.
Dont Rush into things Matt....Your bottom end is going to have to be pretty stout to achieve those numbers....if you want it to live another day...
Here's what you will need for those numbers:
550-575HP 460ci
Intake System:
950cfm Holley DP Carb professionally calibrated for your application
Weiand Stealth Standard Port Intake Manifold
Cylinder Heads:
TFS street heads with mild clean-up and chambers polished
Roller rockers.
Short Block:
Comp Cam 34-652-5 solid flat tappet cam or equivalent
(Specs:294/304 adv., 256/[email protected], .589/.615, 108 LSA)
Compression around 10.5:1
Stock crank
Scat H-beam rods
Block oiling mods
High volume oil pump
Deepened oil pan with windage tray
Exhaust:
1 7/8" headers to dual 3" pipes with H-pipe. Good flowing 3" Magnaflow mufflers or equivalent.
Summary:
91-octane. Keep redline to 7000 rpm.
http://www.fordtruckfanatics.com/forum/showthread.php?t=13578
