460Trucker
Has the Cat Scratch Fever
Hey guys, hope you're having a great holiday season so far. I'm in need of some wheel spacers for my stock 8 lugs. Any suggestions on what manufacturer/type?
Thanks!
Thanks!
Do you not have stock wheels? I've never really noticed..
I do, I've had slight squeaks here and there but its built up to an ear-splitting screech that ruins the whole atmosphere of the truck. I've had someone call me asking if something was wrong with the truck after I drove by them. I decided to run wider tires so I think that's why the issue is more prominent now.
Mike first ide raise the vehicle and spin the wheels,see if you can determine where the rub is located.if you feel you need to go with spacers...Check out summit racings "Eibach wheel spacers" these come in different widths according to your needs and are made from aluminum alloy.Mr Gasket and Cal custom brands are also available however less quality of a spacer.
I've had to grind the calipers on a previous truck I had, when I put some alloy wheels on it.
Hi Mike
Read your posts and came up with a few things,
One, if you put larger tires on a rim, it doesn't change the rim, so if the rim is rubbing on the calipers it's either not the stock rim or maybe someone has upgraded the front brakes to larger calipers?
This rubbing should not be happening with a stock set up
When you pulled off the tires, did the calipers show signs of rubbing damage? Same for a visual on the rim. Hope this helps
