- Moderator
- #21
More info......The pats code has a SSM tied in with it. If a pcm or an instrument cluster is replaced or both, there must be a perameter reset performed or this code is set in the pcm. Cant do a perameter reset because the instrument cluster wont communicate with the IDS. Neither component had been replaced. All connectors are clean and tight. You now have enough information to "cure" it.
