- 147
- 1
This thread will encompass my 521 build. I do all my own machine work as well as engine building. So I will be going in depth with the build as far as a step by step in the machining process and the build itself. So lets get started!
Here we are starting with a D1VE-A2B block. Originally a 429. I have the original crank that I will be saving(or will sell for a reasonable price.)
I started off by boring .020 over to check for cracks in the cylinders. No use paying to have it cleaned if the block isn't usable.
All cylinders good. Off to the blasting booth.
Looking brand new!
I'm going to start off by getting the main housing bores into spec. I only get 4 hours a day to work on this so this will probably be a multi part. First off we need our fasteners.
ARP Studs should do the trick.
All torqued to 110ft. Lbs.
That's all for now. I will be using an Eagle rotating assembly for my build. It's a great value and has all good parts. Forged everything. Here's a link to the kit. http://m.summitracing.com/parts/esp-15011030
More to come. Should update and post daily. Stay tuned.
Looking brand new!
