Ok this starts engine build #7 on Slightly Modified!
I plan on doing this build myself. I am going to keep track with pics and try to build it with part #'s so if someone needs something you can refer to this build. I will have part numbers from Ford and Oreilly's as I work at Orielly's. All part numbers will transfer to CSK also.
As I build I will list part numbers and pics to accompany them.
Today I started with cleaning and painting some of the parts I have on hand. I am going to paint every part on this build since I hope to not have to pull the motor again. I dropped the block off yesterday to get cleaned and tanked to check for cracks. I should have it back later in the week.
I am starting with a white block, all My big accessories will be Dark Charcoal Gray Mettalic, and the little odds and ends will be Black.
The heads have 3 coats of Duplicolor high heat engine Primer and 5 coats of Duplicolor Dark Gray Metallic.
I got a couple of coats on some of the acc. items today as well.
And a coat of primer on the valve covers. I have to sand and prime 2 more times on them.
Should be a fun build this time....
