- 1,320
- 82
Just to add, DO NOT use your torque wrenches as breaker bars, and DO NOT store your click type wrenches with tension on them.
If you read a snap-on torque wrench manual, it states that you should set to and cycle your wrench @ 50% of full wrench torque in both directions before use.
Another no-no is "double clicking" after you hit the set torque. If you must, you need to ratchet the wrench before another cycle. You may bend the rod that makes the audible click, as it is under tension until you ratchet the wrench.
Oh, and no extensions!! Deep sockets only when a short socket won't work!
Just some good info that everybody should practice.
Professionals use ring expanders buzz, not amateurs.
Very easy to distort the ring, not allowing it to sit flat and true in the ring land.
